Wont
Wont May 20, 2025, 10:14 p.m.
Whats the best microphone boom arm that wont randomly collapse during streams and make me look like amateur idiot on camera??
Started streaming couple months ago and my current setup is held together with hopes and dreams - got this garbage $20 boom arm from amazon that literally cannot hold my Blue Yeti without slowly drooping down like dying flower throughout entire stream and viewers keep roasting me in chat about my "droopy mic syndrome" which is absolutely destroying my streamer credibility plus the thing makes random clicking noises every time I adjust position and the joints are so loose that even slight vibration from my mechanical keyboard makes whole arm bounce around like bobblehead so need something that actually works like professional equipment instead of this flimsy piece of chinese metal that probably weighs less than the microphone its supposed to support and yes I know Blue Yeti is heavy but come on this is 2025 surely someone makes boom arm that can handle basic podcast mic without engineering degree required for setup.
marry35
marry35 May 21, 2025, 12:18 a.m.
Blue yeti gang represent! But yeah those mics are absolute units weight wise. Most cheap arms just give up trying to hold them after few weeks of abuse
Shoxi
Shoxi May 21, 2025, 8:02 p.m.
"droopy mic syndrome" 💀💀 chat is ruthless but also kinda funny ngl. at least your viewers are engaged even if theyre roasting your setup
spootsbossy
spootsbossy May 22, 2025, 5:39 p.m.
Mechanical keyboard vibration is real issue. Even expensive arms struggle if your desk shakes every time you type. Might need shock mount or different mounting solution entirely
trang
trang May 24, 2025, 7:20 p.m.
Streaming setup turned into full blown addiction for me. Started with basic webcam now have professional lighting rig and acoustic treatment. Wife thinks ive lost my mind but audio quality is everything
lug
lug May 27, 2025, 11:57 p.m.
Switched to the IXTECH Microphone Boom Arm after my previous setup kept failing during important client calls and it's been rock solid for months of daily use. Holds my heavy condenser mic without any sag issues that plagued cheaper alternatives
Dr.Dream
Dr.Dream May 31, 2025, 7:52 p.m.
Learned the hard way that boom arms hate my particular desk setup because of weird cable management underneath. Spent weekend building custom wooden platform just to get proper mounting surface. Sometimes you gotta get crafty
ars131313
ars131313 June 5, 2025, 1:20 p.m.
My boom arm broke during live podcast recording with 200 people listening and i had to hold my mic by hand for 45 minutes while pretending everything was fine. Never buying cheap gear again after that humiliation
Bird Fancy
Bird Fancy June 8, 2025, 11:12 a.m.
Returned three different arms before realizing my desk was the problem not the equipment. Particle board ikea desk just flexes too much under clamp pressure no matter how expensive the arm is
l?a 2
l?a 2 June 12, 2025, 1:24 a.m.
Blue yeti specifically needs counterweight or spring loaded arm because of how front heavy it is. Regular arms just cant balance that mic geometry properly
Baby best
Baby best June 15, 2025, 6:46 p.m.
Got the RODE PSA1 because my audio engineer buddy threatened to disown me if i kept using garbage equipment during our collaborative projects. Turns out professional gear actually makes difference when you stop being cheap about it
anderson1992
anderson1992 June 19, 2025, 10:22 p.m.
internal cable routing keeps setup clean and prevents cable tension from affecting arm position. External cables create drag that throws off balance on cheaper arms
XXXalex
XXXalex June 23, 2025, 12:03 a.m.
Desk thickness matters more than people realize. Thin ikea desks flex under clamp pressure which makes even good arms unstable. Need solid surface for proper mounting
Sofi_lolo
Sofi_lolo June 27, 2025, 12:18 p.m.
Boom arm shopping is like dating - you think you found "the one" then it disappoints you three weeks later. Currently on relationship #5 with boom arms and getting trust issues
delp.
delp. June 28, 2025, 9:32 p.m.
lmaooo boom arm dating analogy is perfect. they all promise stability then leave you hanging
user
user June 30, 2025, 7:30 p.m.
At least boom arms dont steal your hoodies when they break up with you
1234QWERtyui
1234QWERtyui July 4, 2025, 9:52 p.m.
Shock mounts help but add weight and change balance point. Factor that into arm selection or youll be back to droopy mic problems with heavier setup
dota
dota July 10, 2025, 8:31 p.m.
Asked same question in local facebook maker group and got roasted for using blue yeti instead of xlr setup. Apparently im "doing it wrong" but whatever works for your budget right?
